It is currently Thu Aug 07, 2025 12:49 pm
PostPosted: Thu May 14, 2009 12:04 pm
Hi all.
I have a steel-string I'm doing the final setup on (it's been strung up and played for over a month) and I've been having a hard time finding info on what the general guidelines for relief are.
Cumpiano's and Natelson's book suggest .016" - .031", but that seems a little excessive to me, only because I've heard a few people 'round here throwing in numbers like .003" or .005".
So...
What do you do? I'd be interested to hear about you're preferences for steel string and classicals, flat pickin' and fingerstyling.
Thanks.
-Clint Beacock
PostPosted: Thu May 14, 2009 12:14 pm
Around .005" to .007" for me, usually. And I'm mostly a flatpicker.
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Thu May 14, 2009 12:16 pm
I've recently set one up to .003 and so far I like it.
PostPosted: Thu May 14, 2009 2:16 pm
.007" is what I shoot for.
PostPosted: Thu May 14, 2009 2:46 pm
First name: Rick
Last Name: Davis
City: Seattle
The best discussion of relief I've seen is at http://www.bryankimsey.com/setup/neck_relief_1.htm. Bryan did the math rather than going by intuition. Check it out!
PostPosted: Thu May 14, 2009 3:19 pm
The least amount I can get. I'd have it straight if it wouldn't buzz. So it all depends on your playing style. The harder you play the more the strings vibrate and the chances of fret buzz are more likely to happen although it's related to how low your action is too. If you can leave the neck straight then do. I've also read that you can get a lower action and less relief with a compound radius.
PostPosted: Thu May 14, 2009 3:51 pm
I usually end up between .006" and .010" at the 6th or 7th fret.
Rick, I like that the article distinguishes between action and relief (a lot of players don't get that) but if he is only measuring relief at the 7th fret, the rest of his numbers aren't necessarily very meaningful. The shape of the relief is all important in my book. I don't think in terms of just the number at the 7th fret.
I've seen a lot of Gibson's in for setup work recently where the 7th fret measurement was OK but almost all the curve took place in the first 3 frets. Doesn't work so well and would likely produce very different numbers than he has.
http://www.chassonguitars.com
PostPosted: Thu May 14, 2009 7:02 pm
I use .005
That is what the plek machines setup things for pretty standard as well.
Of course it depends on the player, guitar, and style, but .005 is a comfortable number to shoot for.
PostPosted: Fri May 15, 2009 8:47 am
I'm with Kent on this. Somewhere in the .007-.009" range depending upon scale length and playing style. .005" is too flat, for my tastes at least because it doesn't allow the lattitude that no matter truss rod or graphite, necks and bodies move, and because it is a setup that is only useful for someone with a relatively weak right hand attack. I had a client send one of my guitars to Joe Glaser because they were looking for ridiculously low action. Joe said my fretwork was above the 95th percentile of everything he sees and that the client was being unreasonable. No acoustic guitar I've ever played could I have a relief of .005" without getting some back buzzing unless the player had a very gentle attack. Most of the builders I know are in the range I suggested above.
PostPosted: Fri May 15, 2009 9:06 am
Thanks for all the replies. Much appreciated.
I've set the guitar at around .008" - .010". That article's an interesting read, Rick. And Kent makes a good point about the shape of the relief being important. Lot's of good stuff for me to think about!
How about classicals? Do you tend to shoot for the same range? Or do you give it a little more to help with back buzz (unless you're a flamenco guy and want that sort of thing)?
Regards,
-Clint Beacock
PostPosted: Fri May 15, 2009 10:10 am
Country: Romania
Depends... myself I make it as flat as possible. The string tension will induce a bit of relief, and I also make the bass part of the saddle taller (about 2mm rise over the whole lenght)
I don't think back buzzes are wanted by any guitar player! They are a bit harder to control indeed with a flat FB, but a slightly taller nut fixes it.
Build log
PostPosted: Fri May 15, 2009 10:41 am
I always set my relief around .005 (give or take a thou or two), and I've never had a issue with back buzz except when I cut a nut slot too low. I've plek'ed hundreds of McPherson guitars that had .005 relief (and no adjustable truss rod...) and never had an issue with back buzzing. I play hard with my right hand, and don't have issues. I still use a plek a few times a week now (Norman music) and still routinely see that sort of relief work well.
Bottom line is there is much more going on than the relief. Don't let anyone tell you that such and such relief is the only way to go or you'll have issues. Just because one guy does it this way doesn't mean that's the only way to do it...as we all well know!
Use the numbers as a general guideline and find out what works for you and your guitars.
PostPosted: Fri May 15, 2009 11:18 am
I'm with John on this. As I said, I shoot for .005" to .007" (closer to .007") and I'm a pretty heavy handed bluegrasser. I used to buy in to the whole idea that more relief is necessary for bluegrass, but started slowly lowering my relief thanks to Bryan Kimsey and haven't gone back. Like John said, there's a lot more going on than just relief. Not arguing the fact, of course, that you can achieve an excellent playing guitar with more relief. Again, the key is a well set up guitar with more (or less) relief. A poorly set up guitar with less relief, of course, will have problems.
Wes McMillian
Santo, TX
PostPosted: Sat May 16, 2009 10:33 am
I think that's where the beauty of using a neck jig might be helpful for setting up a guitar. You level the board as it would be under string tension. That helps getting out the humps that can happen by the torque on the head.
PostPosted: Sat May 16, 2009 12:32 pm
Even better yet, the angle iron method shown to us by Rick Turner and others. No simulated string tension here, but the real deal. Eliminates any surprises.
Wes McMillian
Santo, TX
PostPosted: Sat May 16, 2009 12:50 pm
First name: duh
Last Name: Padma
Relief eh? try Rolaids...works fast.
Regarding neck relief and how much, well you gotta bear in mind that
no two cabbages role down the hill the same way.
blessings
the
Padma
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
There's alot of good neck relief advice in this thread. I think .006" is a good number, but it's just a number. Assuming everything else is good if it buzzes only on the low frets it needs more relief. If it buzzes only on the higher frets it needs less relief.
PostPosted: Sat May 16, 2009 12:54 pm
One more thing...ideally the treble side has less relief than the bass. I've been making my necks a bit asymmetrical to control that.
PostPosted: Sat May 16, 2009 12:56 pm
Wouldn't the high frets be a matter of fallaway??
Users browsing this forum: No registered users and 41 guests
